Refreshes the role evaluation for the specified user, for all users, or for all users currently under the specified role.
| user_name |
Specifies a user name for which role evaluation will be refreshed. |
| domain_name |
Specifies a domain name for the specified user. |
| all |
Specifies a refresh for all users associated with the specified role. |
| role_name |
Specifies a a role name for which all users will be refreshed. |
N/A.
It may be necessary to refresh the role of a user due to a new role which might be better suited for the user or due to a change in LDAP attributes of the user which in turn might result in the user being classified under a different role. This command can be used in all such cases.
The following example refreshes the role for user Tony:
* Switch.22 # refresh identity-management role user “Tony”
The following example refreshes the role for all users who are currently classified under the Marketing role:
* Switch.22 # refresh identity-management role all “Marketing”
This command was first available in ExtremeXOS 12.7.
